BraceworksExporting calculation results
Command
Workspace: Path
Export Braceworks Structure
Design Suite: Entertainment > Rigging/Braceworks Reports
Spotlight: Spotlight > Rigging/Braceworks Reports
To export the results of the last calculation:
Select the command.
The Export Braceworks Structure dialog box opens.
Parameter
Description
Export Format
Select whether to export to an .stp file in DSTV format or to a SCIA Engineer XML format
Load Combination
Select <No Load Combination> or choose a load combination. The icon next to the combination indicates whether it is class- or layer-based.
Selection
Select whether the exported results should include all rigging objects in the drawing, or only a subset of selected or visible objects
Managing load combinations
